Old 02-01-2008, 11:05 AM
If you are using the hand module, then you can use the following code:
import hand
h = hand.add(sensor)
#Display as left hand
h.leftHand()
If you are manually loading the hand.cfg file, then you can us the following code:
hand = viz.add('hand.cfg')
hand.scale(-1,1,1)
hand.enable(viz.FLIP_POLYGON_ORDER)
cameras get confused by many LEDs tavaksai Precision Position Tracker (PPT) 9 05-19-2007 05:52 PM
Hand Steve_HT Vizard 1 03-19-2007 01:51 PM
5DT left and right glove glepoura Vizard 3 02-06-2007 05:41 AM
Use of 5DT Ultra left handed glove pattie Vizard 1 08-26-2006 01:59 PM
hand model features? halley Vizard 1 03-13-2006 11:11 AM
