Old 11-30-2007, 10:57 AM
ad_astra ad_astra is offline
continually losing network license
I'm running Vizard 3.0 on XP machines with 1 master and 1 client. The network license for the software is on a third machine, a server shared by the everyone at the research lab where I work.
At least once a day, the master or client machine (or both) pop up with an error that the network license has expired. Usually restarting that machine or the server fixes this but it's becoming a very time consuming problem.
Any suggestions for how to ensure that the license doesn't get lost so easily? Thanks.
Old 11-30-2007, 02:48 PM
The next version of Vizard should resolve this issue and will be released in January. If you need an immediate solution then contact support@worldviz.com and they can supply you with temporary licenses.
Floating license server problems jrodman Vizard 2 10-30-2006 10:39 AM
White Fullscreen crash when running network version Dbuckland Vizard 6 04-19-2006 02:49 PM
For users with a floating license: Adding Vizard License Server as a Service mspusch Vizard 0 03-03-2006 11:36 AM
