Old 08-11-2006, 02:14 PM
paulpars paulpars is offline
in the main.cxx file there is an option to change the size of the data field to any value in order to put values into the data field. I don't understand how this works or how to store data so it can be retrieved from vizard. Also, in the notes it says you can perform a command on the plugin by calling custom.command(0,’’,0,0,0,0). Would you be able to explain how this works?
