Old 05-18-2006, 12:19 PM
Is info.object a valid node when you shoot the face? I suggest that you identify what this object is, and use that object to check if the face is hit.
My experiments have found that the face is quite hard to get viz.intersect to detect. I would recommend you use the box solution if the above solution goes nowhere.
