The following code should fix it. Code:
viz.clip(0.01,1000) |
THANK YOU! That worked perfectly
Crosshair problem
One thing that was weird is that the crosshair shows up separately on each eye when I put on the HMD. Is there a way to fix this?
I'm not sure what you mean. When you view a scene in stereo ALL objects should be showing up separately in each eye. If an object only appears on one eye then you lose the stereo effect. |
What I mean is that 2 crosshairs appear, both showing up on the screen at the same time. The problem is that when I click, bullets come out of the left eye, but nothing comes out of the right eye. Is there a way to make both crosshairs match up so that when I point, regardless of which of the 2 crosshairs I'm looking at, I'll get an accurate shot?
