Thread Tools |
Rating:
Display Modes |
I am trying to use Vizard cluster client with 2 Headset VR PCs running as clients and a Projection VR PC running as the Master. Every time I run the scripts from my Master PC to the clients, the communication is established, however, I get the following error message: "WARNING: Quad buffer stereo is not supported or enabled on your graphics card".
For context, I have NVIDIA RTX Series GPU on my Master and Client PCs. |
Hi, you can try opening up your vizconnect hardware configuration file, then going to Advanced options- Display, click on "Settings" and change the dropdown to not use quad buffer stereo. Let me know if that works.
| Tags |
| cluster client, cluster master, clustering |
| Cluster Master Load Options | apenngrace | Vizard | 1 | 02-03-2023 04:18 PM |
| "Launching in cluster master mode." when cluster mode disabled | jpriede | Vizard | 2 | 02-12-2013 03:33 PM |
| No rendering on Cluster Master | victorqx | Vizard | 1 | 06-04-2012 09:42 AM |
| Automatically set Cluster Master Settings | pcatalano | Vizard | 2 | 01-28-2011 02:09 PM |
| Cluster Help | videcuk | Vizard | 12 | 09-21-2007 03:14 PM |
