Old 06-10-2019, 02:40 AM
zumbay zumbay is offline
move node with main view
Hey,
what would be the best way to link an object so it moves/translates with the direction of the main view (e.g. simulate carrying an object)?
In this example (https://docs.worldviz.com/vizard/lat...nt_control.htm) the car moves with the viewpoint, but not with the head direction, which I would need.
Probably an easy solution to this, sorry!
Thanks!
Old 06-18-2019, 09:10 AM
Use the setReferenceFrame command with mode set to viz.RF_VIEW.
animation path problem - coordinates not resetting jelly Vizard 7 04-26-2016 10:45 AM
Render Node View Matrix whaleeee Vizard 2 05-06-2013 09:26 AM
Main view collision problem AtomicRaiden Vizard 4 10-06-2011 11:48 AM
display the position and euler coords of the main view Josh Vizard 1 03-22-2010 10:48 AM
Plane faces main View jaylocco Vizard 2 07-05-2009 08:21 PM
