Old 07-22-2018, 09:43 PM
amir amir is offline
Optotrak connects through script but not Vizconnect
I use the below code to connect to Optotrak and it works perfectly.
#opto = viz.add('optotrak.dle')
#body = opto.getBody(0)
#viz.link(body, viz.MainView)
However, I can't get it to work with Vizconnect. It's always a red X in the Status column. I've tried it with my computer's hostname and the default hostname in Vizconnect and nothing has worked.
Is there anything I can do to troubleshoot Vizconnect? I'm not sure how Vizard can connect with Optotrak through the script but now through Vizconnect.
Old 07-25-2018, 02:38 AM
Are you running the latest version of Vizard 5? I do remember an issue like this awhile back but I thought it was fixed.
optotrak, vizard, vizconnect
vizconnect optotrak sensors to avatar shashkes Vizard 8 03-14-2016 08:26 AM
Blank screen on external monitor when running a Vizard script with Oculus DK2 mstan Vizard 4 09-03-2015 06:58 AM
Vizconnect and MainView craigpet Vizard 2 08-27-2015 05:41 PM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 06:19 AM
Python script latency after exiting when using InterSense IC2+ fordprefect Vizard 1 03-19-2014 12:58 AM
