Old 05-21-2017, 07:52 AM
bbb bbb is offline
Hi all,
I tried also to do "mountain offset" in the vizconnect tool which works in the piaza model attached to vizconnect but doesn't work properly in my environment. Is there another way to calibrate it such that the movement in the glasses will be in a direct alignment with the enviroment?
Thanks.
