Old 06-07-2016, 01:29 PM
jelly jelly is offline
motion tracker changes Vizard timing
Hello!
I am having very weird timing problems when running my script with the Polhemus motion tracker as opposed to without.
It only happens when I uncomment the section of the code that writes an output file with the position data of the tracker markers. It does not matter if Polhemus is running in parallel, as long as the Vizard script is not using the data.
Has anyone ever had anything similar and knows how to solve this problem?
Thanks in advance!
J
motion tracking, polhemus, timing
Motion Builder + Vizard Objects ForeverBound Vizard 1 04-01-2015 03:49 AM
Unusual tracker sensor setup with Vizard Zhi Vizard 2 06-12-2012 09:52 AM
problem in using xsens motion trackers in Vizard bharatbhushan Vizard 3 01-26-2009 05:51 PM
Can Vizard interact with the Arrington eye tracker? Deltcho Vizard 1 09-18-2007 02:38 PM
