Old 05-31-2016, 05:00 AM
It does not look like there is a velocity command. The available commands can be found in the Sensable and standard sensor pages in the Vizard help. You could calculate the velocity between frames or some other time interval. For example:
import vizmat
viz.addChild('piazza.osgb')
device = sensable.addHapticDevice()
lastPos = [0,0,0]
def calculateVelocity():
	global lastPos
	pos = device.getPosition()
	distance = vizmat.Distance(lastPos,pos)
	velocity = distance/viz.elapsed()
	lastPos = pos
vizact.ontimer(0.1,calculateVelocity)
omni, velocity
Information associated with a model roobert Vizard 7 08-01-2014 09:34 AM
MainView velocity depending on joystick deflection 4711 Vizard 3 01-17-2014 12:50 PM
velocity shader subbu Vizard 0 11-24-2013 06:56 AM
how to remove velocity when mouse is disabled? jvacare1 Vizard 2 02-18-2010 10:25 AM
How Can I use two SensAble Omni at the same time junghungchien Vizard 0 09-03-2009 07:04 AM
