Old 02-02-2016, 02:18 AM
Erikvdb Erikvdb is offline
Here you go, I also included the random wait
import viztask
import random
sound = viz.addAudio('pip.wav')
soundDuration = sound.getDuration()
def playSoundLoop():
    count = 0
    while count < 10:
        count += 1
        sound.play()
        yield viztask.waitTime(soundDuration+random.randrange(1,4))
        sound.stop()
viztask.schedule(playSoundLoop)
Couple of notes:
soundDuration is the duration of the sound you want to play. I use that as the minimal waitTime, to make sure Vizard won't attempt to play the sound again before the first one has finished.
I say attempt, because Vizard won't play the sound from the start if that same sound object is still playing. This was the problem in your code.
This is also why I included the sound.stop() at the end, to make 100% sure the sound is stopped before we try to play it again.
The random.randrange() is the random time after the sound has played for Vizard to wait until the next sound, in this example it'll be between 1 and 4 seconds.
sound loop
preEuler not working? or how to teleport subject multiple times ichitaka Precision Position Tracker (PPT) 1 12-19-2015 03:27 AM
output to multiple (two) sound devices GiudiceLab Vizard 1 08-05-2009 01:12 PM
Multiple Sound Devices GiudiceLab Vizard 2 06-06-2009 10:29 AM
how can I detect when a sound finished playing? bernie Vizard 3 05-10-2007 06:08 PM
Error when playing wav files...? vjonshih Vizard 1 05-23-2005 12:21 PM
