Old 07-10-2015, 09:15 AM
tokola tokola is offline
Cool Weird behavior of on-the-fly objects
I am using a piece of code from Vizard's onTheFly.py example (see below) to create some dots on a map. The dots are created normally when run from within the module ('__main__'), but become square when the module is called from another module (see images)! Absolutely nothing changes in the way the code is called, so it makes no sense to me why this might happen. Seems like a bug.
def DisplayClickedCoords(self,coords):
		#Add on-th-fly points on the map for all the coordinates
		viz.startLayer(viz.POINTS)
		viz.pointSize(20)
		viz.vertexColor(viz.RED)
		self.spots = viz.endLayer()
		self.spots.disable(viz.CULLING)
		for c in coords:
			self.spots.addVertex(c[0], 0, c[1])
		self.spots.alpha(0.5)
I can try and reproduce the problem in a sample script, but before I do this, is there any reason that you think such a behavior can be explained?
ID:	715   Click image for larger version
Old 07-10-2015, 10:09 AM
Is one script enabling multisampling and the other not? Without multsampling enabled, points will usually be rendered as squares.
Old 07-10-2015, 11:05 AM
Easy fix! I knew it would be a piece of cake for you, farshizzo!
I have a hard one coming in another thread, soon
Getting position of a group of objects mape2k Vizard 2 10-31-2013 09:33 AM
Simultaneous Actions on Multiple Objects javadi Vizard 2 07-19-2013 04:54 PM
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 04:07 PM
