Old 06-19-2015, 07:58 AM
Where do I apply a transform mat. for software keystoning?
Hi guys,
We're implementing a webcam + checkerboard based calibration procedure developed by Moreno and Taubin for software keystoning. The procedure compensates for spherical aberrations on the lens of the projector and for non-orthogonal projector placement. This should be very helpful for vizmove, and more specifically, for vizcave and powerwall setups.
The process results in a projector transform matrix that should operate on the pixels of the powerwall projection. The question is: where is the best place to apply this matrix? Should I apply it as a GLSL shader? A property of the viewpoint ?
I'll very happily share once it's complete, hopefully later this summer.
- gD
Old 06-23-2015, 03:14 PM
You would apply this transformation in Vizard using a custom post-process shader.
AR Marker Camera Matrix Transform Problem. pwsnow Vizard 11 06-30-2014 04:48 PM
Apply a texture to a submesh EnvisMJ Vizard 5 12-29-2011 10:34 AM
Modifying transform node in C++ extension rafael Plug-in development 0 09-06-2011 11:48 AM
Matrix Transform and Bumpmap GiudiceLab Vizard 0 11-27-2009 12:42 PM
linear transform in 2D screen space stefs Vizard 1 10-09-2009 10:15 AM
