Old 12-10-2014, 08:20 AM
makinate makinate is offline
Problems with import of fbx avatars into vizard
We are creating virtual avatars from motion capture data in motionbuilder (version 2014) and want to import the fbx files into vizard (version 4). We found an old (2005) tutorial (http://delta3d.org/article.php?story=20051013131730492) on how to export files from maya version 8 into vizard. However, this does not work with the current version of maya.
How do we import avatars from maya (2014) into vizard (4)?
Thanks!
Old 12-10-2014, 02:49 PM
Vizard supports avatars in the Cal3D format and a workflow through 3ds Max. The Cal3D exporter for Max is available from the WorldViz download page. This Cal3D tutorial describes how to use the exporter.
avatar, fbx, motionbuilder
Problems with avatars facial expressions exported with Cal3D armo Vizard 4 08-28-2014 10:57 AM
How to import the defaultdict into vizard knightgba Vizard 3 07-26-2010 01:35 PM
problem with exporting avatars and using them in Vizard VDong Vizard 2 02-23-2009 01:25 AM
euler problems in Vizard 3.0 v-clizzin Vizard 3 08-16-2007 06:10 PM
