Old 11-10-2014, 04:13 PM
1) Make sure the walls are added to the haptic simulation using the device.addNode(node) command. The front of the car (not center) should be aligned with the haptic device if you want resistance when the front touches the wall.
2) The following code should add a spring effect:
sensable = viz.add('sensable.dle')
device = sensable.addHapticDevice()
spring = device.addSpringEffect(gain=0.2,magnitude=0.5,position=[0,0,0])
How to get real time position of a object which is connected to a haptic device Melody Vizard 4 09-15-2014 03:35 PM
haptic device problem guof6570969 Vizard 2 06-09-2010 03:37 AM
Haptic Device Shadows vTony Vizard 1 05-04-2009 06:58 PM
Phantom Omni Device Scripts vSuejung Vizard 1 09-17-2008 05:42 PM
Phantom Device Getting Stuck vjosh Vizard 1 05-09-2005 12:16 PM
