Old 07-16-2014, 04:32 AM
bobbin_93 bobbin_93 is offline
Adding objects
I'm trying to learn how to use Vizard to design a programme for an experiment I'm carrying out.
I've got some images which I would like to add to Vizard as objects. These images are currently in Jpeg format. Does anyone know how to add these into my script?
Once they are in the script I'm also hoping to have them 'flying' at random tangents across the display screen. Is there any code that will automatically create these random tangents?
Thanks.
Old 07-16-2014, 06:15 PM
You can apply the texture to a quad or other object:
http://docs.worldviz.com/vizard/#App...ure_basics.htm
The vizact library includes a number of actions (e.g. vizact.move, vizact.moveTo) that animate objects:
Press the spacebar to move the quad to a random position on X axis
import vizinfo
vizinfo.InfoPanel()
viz.clearcolor(viz.SLATE)
quad = viz.addTexQuad(pos=[0,2,10])
texture = viz.addTexture('ball.jpg')
quad.texture(texture)
def moveQuad():
	randomNumber = vizact.randint(-5,5)
	move = vizact.moveTo([randomNumber,2,10],speed=1)
	quad.runAction(move)
vizact.onkeydown(' ',moveQuad)
Trouble picking text3d objects Salvar Vizard 4 12-01-2010 04:07 PM
Adding Objects to all Scenes jassel41 Vizard 1 11-29-2010 03:35 AM
adding new objects gina Vizard 4 11-29-2006 12:01 PM
