Old 07-06-2014, 07:01 AM
javadi javadi is offline
Sky, Missing Parts
Hello all
I create sky using the following lines
env = viz.addEnvironmentMap('sky.jpg')
sky = viz.addCustomNode('skydome.dlc')
sky.texture(env)
The problem is in some angles the sky is not covering the horizon. Here I have attached three screen shots showing the situation. When you go forward it covers more. It is like this for only some angles. When you turn back it covers the whole horizon. Would you please let me know how to solve it? Thanks.
Greetings
Amir
ID:	658   Click image for larger version
Name:	Sky, when you go forward.png
ID:	659   Click image for larger version
Name:	Sky, when you turn back.png
Old 07-07-2014, 03:31 PM
It may be an issue with clipping. Try increasing the far clipping distance:
viz.MainWindow.clip(0.5, 2000)
Old 07-07-2014, 03:57 PM
Great. Thanks. It works. :-)
Accesing different parts of model pankaj bansal Vizard 1 12-30-2012 10:10 PM
.osg/.ive import - missing geometry & some textures jde Vizard 3 09-04-2009 03:18 PM
scaling avatar's body parts shai Vizard 4 03-03-2008 08:35 AM
missing parts of head texture sjp Vizard 4 10-10-2006 01:10 PM
shadow.py and refract.py missing in trail 2.53 searsky Vizard 3 09-28-2005 08:38 AM
