Old 06-17-2014, 09:09 PM
A value of [0,0,0] is difficult to achieve because the camera would be even with the marker. In the attached image you can see that there is a slight pitch and yaw/roll are close to 0. Each line of output in the image contains orientation and then position values. Based on this it appears most of your single camera data looks correct.
artoolkit
the difference between transform matrix and setEuler,setPosition,setScale arscarsc Vizard 1 08-24-2010 09:17 AM
Camera distance problem CRI Vizard 0 07-28-2010 10:58 AM
Be a Marker for Camera Tracking CRI Vizard 2 05-31-2010 01:09 PM
Matrix Transform and Bumpmap GiudiceLab Vizard 0 11-27-2009 12:42 PM
transform deprecation problem cade_mccall Vizard 7 11-16-2007 02:59 PM
