  #20
Old 07-14-2005, 12:48 PM
I've attached a zip file which contains a script that will remove the border around the window. The zip file also contains the file "win32gui.pyd". You will need to place this file in the same directory as your script. If you use the code in a different script be sure to modify the variable scriptName to the name of your script. Let me know if it doesn't work.
