Hi Farshizzo!
Thank you for you fast reply! ![]() I'll try this and be back to tell you how it worked out. Best, Thales |
| Tags |
| actual monitor frames, frame synchronization, vertical sync |
| Light Baking in 3DS Max causing models to render with seams and transparent faces | dproeder | Vizard | 1 | 09-17-2013 07:45 PM |
| Setting up render node for shadowing | whaleeee | Vizard | 2 | 05-06-2013 11:20 AM |
| How to render a texture of the transparent object and then blur it | whj | Vizard | 1 | 09-25-2012 04:15 PM |
| To Masaki regarding render nodes | surf3rguy | Vizard | 1 | 04-17-2012 06:37 PM |
| How to apply shader and render texture to an object | whj | Vizard | 0 | 04-23-2010 01:23 PM |
