Old 06-21-2013, 03:25 PM
Do you mind posting your vertex/fragment shader code? I tried applying a normal map to a model with mirrored UVs and it seemed to work correctly.
binormal, normal, tangent
Per vertex attributes in OTF objects? stefs Vizard 1 10-23-2009 03:36 PM
Normal Map Workflow for Vizard shivanangel Vizard 2 03-10-2009 06:54 PM
