Old 02-05-2013, 07:55 AM
whaleeee whaleeee is offline
vizinput module missing
I am trying to use some functions that should be included in the vizinput module. However, when I type 'import vizinput', I get this error:
import vizinput
  File "<string>", line 2, in <module>
ImportError: DLL load failed: The specified module could not be found.
I've installed Vizard on two separate computers and they both give the same error. I am using Vizard 4.0 Evaluation version on WinXP and Win7 (x64). Google searches have not revealed where to download the module or how to fix this problem. Can anyone point me in the right direction?
Old 02-06-2013, 12:30 AM
Have you tried running a script that uses the library rather than typing the command through the interactive pane?
import vizinput
vizinput.message('Test')
Exception in module vizjoy fordprefect Vizard 2 12-03-2012 02:41 AM
Free data table GUI module Gladsomebeast Vizard 1 12-23-2008 12:30 PM
missing parts of head texture sjp Vizard 4 10-10-2006 02:10 PM
Fading/lightening-Problem and viz.go in module Johannes Vizard 6 09-02-2005 05:28 PM
vhil module vadrian Vizard 2 01-27-2005 12:52 PM
