Old 01-17-2013, 01:46 PM
Ducky Ducky is offline
Attach a TexQuad to pit.osgb screen
My goal was to texture an image to the screen in the pit example. This I was able to do, but the horizontal lines of the original black screen show through the image. So I thought if I could attach a TexQuad to the front of the screen I could then texture the image onto that and block out the original black screen.
I was able to do this but I feel I took the long route. (attached image)
I would think that after I got a handle on the screen I could apply a TexQuad to it and then texture the imagine onto it, but I keep failing.
I am new to programming so 1) please laugh if this is dumb and 2) if you do please help also.
Old 01-17-2013, 02:57 PM
The best method would be to simply remove the texture containing the horizontal lines. The following sample shows how to accomplish this:
pit = viz.add('pit.osgb')
# Apply texture to screen
image = viz.add('images/tile_wood.jpg')
pit.texture(image, node='screen')
# Remove screen line texture
pit.texture(0, node='screen', unit=1)
Using a texquad to cover a window Enlil Vizard 4 02-07-2012 03:13 PM
Splash screen split in half sleiN13 Vizard 1 12-20-2011 03:50 PM
split screen honey006 Vizard 3 05-21-2009 09:57 AM
screen image erchrastil Vizard 8 06-27-2008 11:45 AM
position of html-file on screen active_world Vizard 1 05-16-2008 07:24 PM
