Old 09-25-2012, 01:17 PM
leoaered leoaered is offline
Thanks for that, farshizzo. One last question:
How would I tie everything together and add the model matrix to the equation? Do I have to perform any operations/conversions on this matrix as well? Also, what is the multiplication order of model, view, and projection matrices?
<node3d>.getMatrix() on objects doesn't seem to work properly without either an inverse() or the same conversion you used for the view matrix. This seems really weird to me because I manually checked that the transformation matrix was correct as is.
I'm simply trying to send the MVP to the shader, but everything seems to be flipped from what I'm used to. For example, P * V * M seems to be the wrong multiplication order. I also don't understand why you needed to do the conversion on the view matrix.
Thanks again!
Vizard Headlight in Shader shivanangel Vizard 1 06-27-2012 01:19 PM
SSAO Shader Implementation FranciscoPeters Vizard 2 10-08-2011 04:19 AM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
Specular Shader Issue shivanangel Vizard 2 05-06-2009 11:08 AM
