Old 07-25-2012, 02:59 AM
victorqx victorqx is offline
Vizard cluster with director calls
Perhaps this question has already been answered, but I couldn't find it. If it has been answered before, could someone please point me in the right direction to find the answer?
As background, I'm running a powerwall with 6 screens and thus 6 rendering machines.
I want to be able to switch scenes in Vizard while a script is running. I'm creating thumbnails of different scenes and via a touchscreen like interface I want to allow a user to switch between these scenes. Since some of these scenes are quite big, it can take the cluster some 10-20 seconds to load them. In this time period I would like to display a 'loading...' message so the user knows that something is happening.
I created a fancy, animated loading message with spheres that change opacity. I tried to get Vizard to load the new scene in a background thread using the director, on my desktop this works fine. When switching to the cluster, the animation doesn't run.
Is it possible to run a background director call on a cluster?
Thanks in advance for any tips!
Regards,
Victor
PS Code for loading a scene:
scene = None
def loadSomeScene():
	global scene
	scene = viz.addSphere()
def loadScene2(loadFunc):
	if not scene == None:
		scene.remove()
	LoadingAnimation.showLoadingSpheres()
	yield viztask.waitDirector(loadFunc)
	LoadingAnimation.removeLoadingSpheres()
def loadScene(loadFunc):
	viztask.schedule(loadScene2(loadFunc))
vizact.onkeychar('1', loadScene, loadSomeScene)
Old 08-03-2012, 04:42 PM
No, currently you cannot run background director calls within a cluster. The clients will just execute the calls in their main thread. We are working on adding a built-in option to load models asynchronously to a future version of Vizard, which would also work with cluster clients.
Old 08-06-2012, 12:24 AM
Hello farshizzo,
Thanks for your reply. It is unfortunate that director calls won't work in a cluster. I'm looking forward to a new version in which to load models asynchronously. For now, I'll make do with the UI freezing for a bit while models are loading :-)
Regards,
Victor
Fall 2007 release of Vizard R3 3 D Announcements 0 10-15-2007 04:50 PM
