I think the code you are using is changing the PPT data before it is applied to the viewpoint. PPT always outputs in meters and is oriented in the positive z direction of the calibration square. Try running only this code only:
viz.add('court.ive')
vrpn = viz.add('vrpn7.dle')
tracker = vrpn.addTracker('PPT0@hostname',0)
def updateView():
pptPos = tracker.getPosition()
viz.MainView.setPosition(pptPos)
vizact.onupdate(viz.PRIORITY_DEFAULT, updateView)
Paul Elliott WorldViz LLC |
| Realistic Light and Shadows Using Vizard and 3DS Max | jde | Vizard | 4 | 07-13-2012 10:58 AM |
| Vizard 4 Beta Testing | farshizzo | Announcements | 0 | 02-01-2011 10:46 AM |
| Vizard 4 Beta Testing | farshizzo | Vizard | 0 | 02-01-2011 10:46 AM |
| .3DS importing in Vizard and 3D Studio | jde | Vizard | 1 | 08-28-2009 03:14 PM |
| Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 11:13 AM |
