Old 08-29-2011, 10:28 AM
WaterBottle WaterBottle is offline
Adding Audio to CAF Animation
What i need to do is play audio and a animation at the same time. I would like to combined those in one .caf file. Using 3ds max how can i make the caf file have audio so if i play it in vizard? Thanks
Old 08-29-2011, 10:42 AM
The Cal3D .caf file format is just for animations. In Vizard, you could play audio when the animation begins and stop the audio when it's done.
Old 08-29-2011, 11:00 AM
I was thinking about doing that but every time i play an audio and a animation at the same time one waits for the other to be complete. I tried using
viz.playSound('filename')
self.VizBody.state(1)
I know there must be a better way to do this i am just new to vizard.
Old 08-30-2011, 06:54 PM
You could use a task function to play audio and stop if after the action is done:
import viztask
avatar = viz.addAvatar('vcc_male.cfg',pos=[0,0,5],euler=[180,0,0])
avatar.state(1)
action = vizact.animation(3)
audio = viz.addAudio('jfk.wav',loop=1)
def animationTask():
	while True:
		yield viztask.waitKeyDown(' ')
		audio.play()
		yield viztask.runAction(avatar,action)
		audio.stop()
viztask.schedule(animationTask())
If the sound is attached to the avatar you could use a sequence of actions:
avatar.state(1)
startSound = vizact.method.playsound('jfk.wav',viz.LOOP)
stopSound = vizact.method.playsound('jfk.wav',viz.STOP)
actionSequence = vizact.sequence(startSound,action,stopSound)
vizact.onkeydown(' ',avatar.addAction,actionSequence)
animation, caf
Clarification on CAL3D Avatar Animation in Vizard shivanangel Vizard 2 11-22-2010 07:16 AM
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 11:22 AM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
avatar animation problems jrodman Vizard 1 01-18-2006 09:12 AM
