Old 06-29-2011, 04:55 PM
Lithium Lithium is offline
Exporting textures from Sketchup to Vizard
I am exporting a simple model from SketchUp into Vizard ( viz.add(file.dae) ).
The basic shapes look fine but the textures do not load in Vizard .The output reports warnings like this:
"Warning: could not find file "/Z:/PEOPLE/Lilith/showermodel2/texture9.jpg"
processTexture(./ID9)"
This is the correct pathname for the jpg, though, and there seems to be nothing wrong with the jpg itself.
The only things I can think of are the extra slash before the drive name, and the fact that they are forward- rather than back- slashes, but I don't think either of those are the issue.
Does anyone know what is going on and how to solve this problem? Thanks in advance!
Old 06-29-2011, 05:12 PM
Have you tried placing the .dae file and the texture folder at the same level as shown in the Loading the model in Vizard section of this article?
Old 06-29-2011, 06:03 PM
Yes, the .dae file and the folder containing the textures are in the same level, same folder. I think I followed everything according to the article.
Old 06-30-2011, 12:00 PM
Can you upload the model here so I can take a look?
Old 06-30-2011, 01:38 PM
Sure, the upload reference code is 621666.
Thanks for your time!
Old 06-30-2011, 04:33 PM
When I loaded the model the textures were there. What is the version number of Vizard 3 that you are using? Check that by going to Help -> About Vizard.
Old 07-05-2011, 11:24 AM
That seems to have been the problem! I upgraded to the most recent version of Vizard3 and the textures are there now.
Thanks for your help!
.dae, collada, sketchup, texture, textures
Exporting Mult-Sub Obj Textures from references in Max using IVE/OSG shivanangel Vizard 3 02-10-2010 02:09 PM
Max -> Vizard, Two Sided Textures shivanangel Vizard 5 12-04-2008 04:15 AM
Exporting from Maya to Vizard jfreeman Vizard 2 06-30-2005 03:14 PM
