Old 06-20-2011, 09:04 AM
sleiN13 sleiN13 is offline
Wrong textures with OSGexp export
I've been using the OSGexp(version 1.0.0) in combination with Max 12 and Vizard 4, and it works fine if I export to the .osg format with a texture (image) folder. But as soon as I export to .ive with integrated textures the textures are all wrong. The end result is something between a inverse color operation and a drugs overdose.
Is this caused by the export settings? and how can I correct this. Exporting using max 11 and the vizard 3 plugin with the exact same settings does export correctly.
Applying textures to objects made in Blender andrewjworz Vizard 0 04-21-2011 06:15 AM
OSG IVE export 3dmax with baked textures chris_user Vizard 2 04-12-2011 10:33 PM
Missing textures in an executable Dave Vizard 7 10-22-2010 07:59 AM
Multiple Textures for Diffuse and Specularity Shader Issue shivanangel Vizard 1 05-11-2009 10:44 AM
Max -> Vizard, Two Sided Textures shivanangel Vizard 5 12-04-2008 03:15 AM
