Hi Tobin,
I used the DXT1 compression. Now the problem solved (See attached screen-shot). Great! Thank you for your suggestion. By the way, what is the difference between the different compression modes. How does user know which mode to use? |
| How to render a texture of the transparent object and then blur it | whj | Vizard | 1 | 09-25-2012 03:15 PM |
| How to apply shader and render texture to an object | whj | Vizard | 0 | 04-23-2010 12:23 PM |
| Change model alpha and memory leak | hosier | Vizard | 2 | 06-25-2009 10:55 AM |
| Successful Cal3D Export But Texture Problems | ezanih | Plug-in development | 2 | 01-26-2009 04:28 PM |
