Old 05-10-2011, 09:45 AM
Zhi Zhi is offline
Originally Posted by farshizzo View Post
Try disabling the "Free image memory" option. If that doesn't work then you'll need to open a support issue and supply the max file so our artist can have a look at it.
Unfortunately, disabling the "free image memory" option does not help. Attached figure was rendered under the viz.FULLSCREEN mode in Vizard. The left half image was the screen of a LED monitor, the right half image was the virtual screen generated by the Matrox TripleHead2Go splitter.
The weird texture was not happened to a particular 3ds model but to all the 3ds models I have exported to Vizard. It seems it is a problem of the compatibility between Matrox and Vizard (because Matrox with Virtools does not have such a problem).
I am using the beta2 version of Vizard 4. We have not bought Vizard yet. Am I eligible to the support. If I am, how to open an support issue. Thank you!
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
Successful Cal3D Export But Texture Problems ezanih Plug-in development 2 01-26-2009 04:28 PM
