Old 04-11-2011, 07:59 AM
xcuddlex xcuddlex is offline
vizard marker visible
i know this code is to display avatar only when the marker is shown
#Add ARToolkit extension
ar = viz.add('artoolkit.dle')
#Create camera using first available webcam
camera = ar.addWebCamera()
#Create matrix marker
marker = camera.addMatrixMarker(0,width=1000)
#Add avatar model and set state 1
avatar = viz.add('vcc_male.cfg')
avatar.state(1)
#Link avatar model to marker sensor
viz.link(marker,avatar)
#Method that update if the marker is visible
def updateVisible():
if marker.getVisible():
avatar.visible(viz.ON)
avatar.visible(viz.OFF)
vizact.ontimer(0,updateVisible)
but what if i have multiple avatar? i want to display avatar1 only when marker1 is shown to the camera? and avatar2 only when marker2 is shown and so on. python does not have switch statement right? please help !
Old 04-11-2011, 05:52 PM
You could use multiple if statements in the updateVisible function.
Old 04-18-2011, 02:54 AM
marker1.visible(viz.ON)
elif
marker2.visible(viz.ON)
this doesnt work
i got an error and it wont run
is the syntax wrong ? i'm not familiar with python
