I verified the vizard version: 2.50b Next, i installed the latest drivers. note this is a dell machine and the regular ATi-website drivers did not work. But the date of the drivers of the dell website seemed to match the ati drivers published on their website (well almost, that is). This is an older Ati Rage 128 Ultra chipset. Unfortunately this card does not use the catalyst driver set. Other sys specs: P4 2.4 512mb on Windows 2000 etc. (Dell precision 340) Another problem i'm running into is complete system locks on running the 3D demo's. (ctrl-alt-delete, alt-f4, alt-tab = no response, no more mouse-movement either). This first happened with the "mini"-cardemo, and just a few minutes ago also on other demo's, this time i ran collision demo to check the font problem, and as i dragged the 3d window i got the lockup. At the moment i can not test another Ati-board @ work. I could at home though on an x800 card, but as u know i will be developing @ work, so that's no solution. I'll check if i can get a hold of another card here. Do you have any other suggestions, regarding the system lock-ups and unreadable text? (system is up-to-date as far as possible, and has anti-vir mcaffee etc) thanks in advance, greets, Kevin Last edited by exhale; 02-23-2005 at 02:11 AM. |
