Old 03-01-2011, 09:34 AM
new_horizon new_horizon is offline
Thanks for the reply Jeff - I decided to try to use the Inifinite Terrain and coat it in a tarmac image in order to increase the tesselation...
#Add a texture and set it to repeat mode.
grass = viz.add('tarmac.jpg')
grass.wrap(viz.WRAP_S,viz.REPEAT)
grass.wrap(viz.WRAP_T,viz.REPEAT)
#Add the terrain using the infinte terrain plug-in.
terrain = viz.add('InfiniteTerrain.dlc',1,'456',8,1000,400,1 0000)
#Texture the terrain.
terrain.texture(grass)
terrain.command(1,'',0,0)
terrain.appearance(viz.TEXMODULATE)
However, I am still getting this jagged light effect - almost as if it is passing the light onto one object and then another - just at a faster pace. Is there anyway of smoothing this? Any increase in tesselation value (over 8) for the terrain results in my PC crashing - if an increase is likely to improve this effect, I can find another PC.
Thanks - I appreciate your help!
Lighting Question new_horizon Vizard 12 02-24-2011 08:11 AM
question about NVIDIA 3D vision Weihua An Vizard 5 08-02-2010 06:49 AM
Stereoscopic view question atamasan Vizard 2 03-09-2010 09:13 PM
how to invoke command line question billjarrold Vizard 2 01-11-2010 08:51 AM
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 10:15 AM
