Old 11-22-2010, 10:30 AM
Hi sleiN13,
OSG Occluders are found under Helpers in the Create tab of the command panel. Select OpenSceneGraph from the dropdown list and the option should appear.
Doing occluders in OSG requires two things:
-The helper
-Rectangular splines that get added to the helper
Invisible haptic objects Haptiken Vizard 1 05-05-2009 04:04 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 05:19 PM
