I've finally switch to the osg/ive export format for my world to be able to use the occlusion helper.
I'm using 3ds max 2011 and OSGEXP 0.9.8 but can't seem to find the occlusion helper anywhere in the menu's. Do i need to install some addition software (openscenegraph) or set some options if max to get the occusion helper options? |
| Semi-circle array containing target and distractor objects | ptjt255 | Vizard | 3 | 08-04-2009 03:09 AM |
| Invisible haptic objects | Haptiken | Vizard | 1 | 05-05-2009 04:04 PM |
| Lightwave objects rotation problem | hosier | Vizard | 6 | 02-13-2009 12:04 PM |
| Improve performance with large number of onthefly objects? | Fox5 | Vizard | 7 | 04-28-2008 05:19 PM |
| Could not find plugin to load objects... | halley | Vizard | 1 | 05-30-2006 11:01 AM |
