Old 10-18-2010, 07:28 AM
nige777 nige777 is offline
Red face re: render nodes and scenes
Hi, I'm trying to render to contents of a second scene to a texture and apply that to a TexQuad, is this possible because if I had any hair I would have started to pull it out - here's an example of the method I have been trying so far:
viz.clearcolor(.9,.9,1)
#Add something to scene 2
viz.add('panorama.ive',scene=2)
renderTexture = viz.addRenderTexture() #Create render texture
#Create render node
renderNode=viz.addRenderNode(scene=2)
renderNode.attachTexture(renderTexture)
renderNode.setInheritView(False)
#Add and set Position of in-world-screen
screen = viz.addTexQuad()
screen.setPosition([-.2,1.6,2.5])
screen.setEuler([178,0,0])
screen.texture(renderTexture)
Am I missing something or is this not possible??
As usual I will be VERY grateful for any help with this issue
Old 10-18-2010, 09:54 AM
Your example code is adding the render node to scene 2. Instead, you should add the render node to the main scene and have it render scene 2. The following change should do this:
renderNode=viz.addRenderNode()
renderNode.setScene(2)
Old 10-18-2010, 02:14 PM
thank you, I couldn't see the wood for the trees
While I'm here I'd like to check whether it's possible to use or even trap the mouse / cursor in a scene other than the first one?
