Old 10-06-2010, 11:42 PM
Chapre Chapre is offline
Question checking object location in an inclosed area of the world
Hello, is are there function that can help me check if an object is inside an area or inside another object.
illustration 1: how will I check if a wheelchair is inside the train or inside house
illustration 2: how will I check if a wheelchair is inside an inclosed area in the world
Old 10-07-2010, 12:48 PM
If you have the bounding box the enclosed area and the position of the wheelchair, then you can use the following code to check whether the wheelchair is inside the enclosed area:
# bb is bounding box of enclosed area
# p is [x,y,z] position of wheelchair
if (bb.xmin <= p[0] <= bb.xmax) and (bb.ymin <= p[1] <= bb.ymax) and (bb.zmin <= p[2] <= bb.zmax):
	print 'Wheelchair inside'
	print 'Wheelchair outside'
Old 10-08-2010, 12:57 AM
Thanks a lot farshizzo, this is what I needed
why is time faster in my virtual world? billjarrold Vizard 1 11-24-2009 05:33 PM
Gps input for viewpoint location? realvision Vizard 3 03-19-2008 12:37 PM
Object rotating around world axis, not own axis tacbob Vizard 1 02-15-2007 09:12 AM
