Old 07-19-2010, 04:45 PM
masaki masaki is offline
There isn't a built in Vizard function for occlusion tests - you would have to manually do this, but performing this test will also increase the load on your cpu, especially if you're doing it every frame.
Best,
Masaki
Invisible haptic objects Haptiken Vizard 1 05-05-2009 05:04 PM
Improve performance with large number of onthefly objects? Fox5 Vizard 7 04-28-2008 06:19 PM
