Old 07-07-2010, 11:59 AM
Enlil Enlil is offline
Complete character cfg file relative directories
We are using several complete characters and would like to keep one central repository for the animations. We found that using absolute file positions (ie animation=c:/foo/animation/anim.caf) works, but aren't sure what the convention for relative files is (ie animation=../animation/anim.caf). We tried a couple, but the parser did not recognize. How should the relative directories be referenced?
Christian
Old 07-09-2010, 05:30 AM
You can viz.res.addPath to specify a path where Vizard will search for resources. Does that work for you?
Old 10-02-2013, 10:08 AM
Hi Christian,
You can use relative files in the .cfg files of complete characters in this way:
skeleton = Skel\male_high_Skeleton.CSF
Closing of an imported .py file Uttama_vizard Vizard 2 05-04-2010 06:18 AM
IVEx file extenstion unrecognised. sindi Vizard 2 12-10-2009 01:20 AM
Read file....many issues Uttama_vizard Vizard 9 07-08-2008 02:16 PM
File Management Uttama_vizard Vizard 2 07-01-2008 09:44 AM
