Old 10-08-2009, 02:46 PM
Your model seems to work fine for me. Here is the script I used to test it out:
viz.add('tut_ground.wrl')
model = viz.addChild('testtree.lwo')
model.drawOrder(-1) #Ensure model is rendered to depth buffer before other models
model.disable(viz.COLOR_WRITE)
import vizcam
cam = vizcam.PivotNavigate()
cam.centerNode(model)
cam.setDistance(model.getBoundingSphere().radius*5)
cam.rotateUp(10)
Old 10-09-2009, 07:38 AM
Boerske Boerske is offline
Cool it works now.
Thx
It was the "node.drawOrder(-1)" line what made the difference.
what does this exactly do? As a newbie I do not really understand why it is important that the model is rendered before others....
for the future - if i load more of these specific models do they all need this specific drawOrder function???
Anyway, thank you very much helping me at this problem.
Regards
Phil
Old 10-09-2009, 10:18 AM
The object you want to have occlude other objects must be rendered to the depth buffer first. The default draw order of objects is 0, so setting the draw order to -1 ensures it is rendered before other objects.
view problem nlfrnassimi Vizard 3 03-11-2009 08:33 PM
export problem bazelaisr Vizard 2 05-28-2008 10:19 AM
5DT Data Glove 5 Ultra Problem bjgold Vizard 1 08-08-2006 04:08 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
