Old 08-20-2009, 12:55 PM
Can you post a simple script that recreates this? It sounds like you might be modifying the pitch of the duck or your ground plane is not level.
Old 08-21-2009, 08:52 AM
GiudiceLab GiudiceLab is offline
Tilted duck...
Aha! I figured it out when I was creating the test script for you--I had the duck looking at [0,0,0], which meant it was tilted. I changed it to the look at the correct height [0,height,0], then centered and translated it at the correct height and that fixed the issue.
Thanks anyway!
Virtual Environments and Multimodal Interaction (VEMI) Lab
This time, it should work...
moving and object by mouse but don't know how to stop the movement nlfrnassimi Vizard 8 04-26-2009 07:23 AM
Moving avatars lips with sound dan12345 Vizard 5 01-29-2008 07:32 PM
sound problem alaa Vizard 7 09-02-2005 01:13 PM
Moving view with object Xliben Vizard 2 07-25-2005 05:36 PM
