Old 05-15-2009, 05:12 AM
minawageh minawageh is offline
Exclamation graduation project need help
in my project i wanna assemble a pump manually so
i wanna use snaping tool to help in assembling it as if you pick an object and get close enough to onther object and with suitable position and rotation it will be oriented so i can slide it along onther part axis (mainly x-axis) so i wanna calculate to differance between there position taking in considration orientation differance
so if it can be done any way i wanna know very soon
and i was trying use matrix to calculate it but till now i can't so i need help as soon as possiable
THX
MinA
Old 05-15-2009, 11:44 AM
The vizmat module has the functions you need:
if vizmat.AngleBetweenVector(partForwardVector, fittingForwardVector) < 5
and
if vizmat.Distance(partPos, fittingPos) < .1:
snappySnap()
Old 06-08-2009, 04:21 AM
Exclamation
and
snappySnap()
thx very much for help but i can't understand this command could u plz explane what are the parameters and how can i atach the vectors to my objects
and i have onther problem with collision i have a complex shaps so i tried to use collidMesh but it didn't work as if i pick object it collide with others could you explane hoe to use it and if there any way to make collide shape for hollow cylinder
thx again
Old 06-08-2009, 12:02 PM
You can get the forward vectors of the parts and fittings from their transform matrices.
partForwardVector = part.getMatrix().getForward()
The physics system does not support dynamic forces, like gravity, on collideMesh shapes. Complex shapes need to be made up of multiple simple shapes like boxes and spheres.
What you'll want to do is name some sub-nodes of your hollow cylinder and call collideBox(node="subobject1") on them. The docs have an example on this with the table.wrl object:
table = viz.add('table.wrl',pos=[0,3,6.5],euler=[90,45,90]) # Add table
table.collideBox(node='Leg1') # Define
table.collideBox(node='Leg2') # collision
table.collideBox(node='Leg3') # area
table.collideBox(node='Leg4') # for
table.collideBox(node='Top')  # parts
Old 06-30-2009, 03:11 AM
thx very much for your help but i don't know how to make sub-nodes and i don't know if i can do it in vizard or i must make it in athor programes like 3d max
and i don't know what to do with
and how to use it
Need help with a project mberkes Vizard 14 05-27-2009 11:54 AM
New project need HELP minawageh Vizard 5 03-17-2009 03:17 PM
Project .avi or .mpeg file pattie Vizard 2 02-06-2007 08:09 AM
