Old 03-14-2009, 05:52 AM
mustufahaider mustufahaider is offline
Send a message via Skype™ to mustufahaider
How to build an environment
Can anyone help me to buid a simple room with cieling lights and a center table with some parts like piston, bearing etc. lying on it. and then i want an avatar to pick one part and then assemble it with another part using his hands. and how can we move an avatar to a pre-defined path?
If there is some code please tell me that to do all the above stated things?
Thanx in advance.
Old 03-16-2009, 10:10 AM
The room.wrl model that can be found in the Vizard30/tutorials/gettingstarted folder has ceiling lights. Maybe you could use that. This page from the Vizard docs provides links to several sites for models online, where you could find a table model to add to your room. Many free ones are available
For assembling objects that have been picked try looking through tutorials and example scripts related to picking, linking, and grabbing. These will give you some ideas of how that would work.
If you want your avatar to walk along a certain path try using vizact.walkTo
orthographic projection in a head-tracked cave environment michaelrepucci Vizard 5 12-14-2011 10:29 AM
navigation in cave environment Andy Vizard 4 03-28-2008 01:32 AM
Getting a mirror to work in any environment Frank Verberne Vizard 5 03-27-2008 08:21 AM
Best Modelling Environment for Vizard? tmcw Vizard 6 02-24-2007 11:15 AM
environment maps, scenes, and you! vadrian Vizard 1 01-12-2005 04:04 PM
