Old 11-17-2008, 07:37 AM
asafox asafox is offline
Question changing spacing/angles for the eye-input in the HMD
hi,
I wanted to ask, is it possible to change the input received by the helmet so that the eyes are in different spacing/angles?
(meaning, instead of the eye-input in the helmet automatically showing the view of 2 different cameras that are ~10cm apart from one another and are looking at about the same agle, change the spacing and/or the angles of the eyes)
Old 11-17-2008, 04:49 PM
I think you are referring to the IPD (Interpupilary distance). You can set the IPD when viewing in stereo by using the viz.ipd command. For example, if you want the eyes to be separated by 5 cm you would use the following code:
viz.ipd(0.05)
How to input several model files and then save one output file mspusch Vizard 1 07-15-2008 10:30 PM
input & gamepad dominic Vizard 1 08-15-2005 04:01 PM
problem with input boxes shai Vizard 6 08-15-2005 10:51 AM
