Old 05-17-2007, 09:49 PM
TunTun TunTun is offline
Change Resolution
Is there any parameter or function that can change the resolution of the output graphics? Say sometimes I need 1024x768, sometimes I need 512x389.
Thanks.
Old 05-18-2007, 10:11 AM
Are referring to the monitor resolution or the size of the graphics window? Either way, have a look at the following commands in the documentation:
viz.displaymode()
viz.windowsize()
Old 05-18-2007, 11:42 AM
Thanks. I'll try viz.displaymode().
BTW, what's the width/height of viz.windowsize(width, height)? If they are the number of pixels, then what's the difference between these two commands?
Old 05-18-2007, 11:47 AM
viz.displaymode() changes the resolution of your monitor
viz.windowsize() changes the size of the Vizard graphics window
Old 06-12-2007, 01:56 PM
Our HMD is nVisor SX which can display a 1280x1024 image. I tried to use viz.displaymode(640,512) at the beginning of my program to get half resolution. But I get the following message and nothing changed.
** ERROR: Failed to set requested display mode
Did I miss something?
Old 06-12-2007, 02:07 PM
Your monitor does not support that resolution. Why do you want to set the resolution to half?
Old 06-12-2007, 03:10 PM
I also tried to set the resolution of my monitor, but then I can see nothing but color stripe in my HMD.
