The command that you showed returns the transform of the object in the specified coordinate system.. But, my goal is to find the 4x4 matrix of the object after loading into the virtual environment and print those values. Can you provide me with a simple example of how it can be achieved? I would be grateful if you could help me out. Thanks in advance. |
Hi Jeff,
I'm sorry I understood your point now. The command is exactly what I wanted. Could you provide me with an example of how can I obtain the 4x4 matrix using node3d.getmatrix(). |
| Thread Tools | |
| Different projection matrix per viewpoint | dcnieho | Vizard | 6 | 07-08-2016 05:06 AM |
| AR Marker Camera Matrix Transform Problem. | pwsnow | Vizard | 11 | 06-30-2014 04:48 PM |
| Render Node View Matrix | whaleeee | Vizard | 2 | 05-06-2013 09:26 AM |
| Projection Matrix (onto oblique near plane) | andrewjworz | Vizard | 1 | 07-13-2012 09:10 AM |
| Matrix Transform and Bumpmap | GiudiceLab | Vizard | 0 | 11-27-2009 12:42 PM |
