Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Old 08-11-2016, 09:05 AM
About external lib
I am about to install external lib to Vizard.
When I opened Tool, package manager and searched numpy, it showed up there is numpy1.11.1.
However, when I pressed installed, the following showed up.
"Collecting numpy
DEPRECATION: Failed to find 'numpy' at https://pypi.binstar.org/carlkl/simple/numpy/. It is suggested to upgrade your index to support normalized names as the name in /simple/{name}.
Cannot fetch index base URL https://pypi.binstar.org/carlkl/simple/
Could not find any downloads that satisfy the requirement numpy
No distributions at all found for numpy"
Is there any solution for this?
Old 08-11-2016, 10:15 AM
and there is one more question.
When I try to install numpy in Cmd command (right beside the search word)
it came out "UnicodeDecodeError: 'ascii' codec can't decode byte 0xd3 in position 9: ordinal not in range(128)"
I know the problem is "ascii" and "utf-8" code problem.
Is there a general way to solve it?
Old 08-12-2016, 01:11 AM
There are official numpy 32 and 64 bit binaries on the PyPi site. You can download the compatible .whl installer for your platform (numpy-1.11.1-cp27-none-win32.whl or numpy-1.11.1-cp27-none-win_amd64.whl) and drag/drop into the Vizard 5 editor to install.
https://pypi.python.org/pypi/numpy/
The package manager will be updated in the next Vizard release to find the numpy installers here.
Old 08-12-2016, 08:12 AM
it works, thanks for that
Old 01-20-2017, 10:35 AM
i install pyqtgraph meet the same problem, is there any solution?
Old 01-20-2017, 01:51 PM
this is the error comes out "UnicodeDecodeError: 'ascii' codec can't decode byte 0xd3 in position 7: ordinal not in range(128)"
Publishing with external libs fabioped Vizard 2 06-08-2017 04:25 AM
Blank screen on external monitor when running a Vizard script with Oculus DK2 mstan Vizard 4 09-03-2015 05:58 AM
External package problem from Vizard Package Manager pwsnow Vizard 1 06-13-2014 09:11 AM
Collision recording and external data saves just alex Vizard 2 01-29-2010 09:46 AM
External Trigger via LabJack ursi Plug-in development 10 01-21-2010 10:57 AM
