Old 11-10-2015, 01:40 PM
bbb bbb is offline
help with mouse as tracker position
Hello everyone,
I'm using a trackball mouse for navigation and i want that the mouse will act as a tracker position in order to link it to the main view (to set the point of view of the user according to the mouse). I need to get the x and z coordinates of the mouse constantly while maintaining the y coordinate fixed to 1.8. The reason for using a tracker is because i want to initiate different starting position with randint methode.
I saw an explanation about vizconnent but i didn't understand exacly how to use it and i'm not sure it can resolve my problem.
Thanks in advance and have a nice week.
Old 11-10-2015, 03:33 PM
You could get the mouse position every frame using viz.mouse.getPosition() and multiply the values returned by some scale factor to simulate position data.
Old 11-15-2015, 12:37 AM
bbb bbb is offline
Thanks for your help but i also need a function similar to getPosition that will give me an information about the z coordinate of the mouse so i don't understand how does the getPoition methode can solve my problem.
I found in vizconnect a tracker "mouse speen wheel" but according to the information provided by the vizconnect the x coordinate is replaced by the x coordinate. Is there any tracker in vizconnect or another methode in viz.mouse that can give x,y,z coordinates?
Old 11-15-2015, 12:56 AM
bbb bbb is offline
Thanks Jeff but the getPosition methode provide information about the x&y coordinates but not on the z coordinate. Is there any methode or tracker that provide information of x&y&z coordinates?
Old 11-16-2015, 03:32 PM
The ScrollWheel tracker included with the vizconnect library returns Z position data. This could be combined with the X and Y data returned from the viz.mouse.getPosition() function:
from vizconnect.util.virtual_trackers import ScrollWheel
mouseTracker = ScrollWheel(scaleVelocityWithDistance=True, extensionAccel=100, debug=False)
def printData():
	print mouseTracker.getPosition()
vizact.ontimer(1,printData)
Set Mouse Position javadi Vizard 2 11-19-2013 03:59 AM
get tracker position and euler chris_user Vizard 2 07-01-2011 01:31 AM
Mouse event: how to detect no mouse move event, how to set mouse position? Zhi Vizard 3 04-11-2011 06:25 PM
set mouse position AlyssaK Vizard 1 01-28-2009 04:05 PM
Can you link the position of a tracker to the orientation of an object? michaelrepucci Vizard 1 09-19-2008 10:23 AM
